Use the following procedure to limit data transmission during the session.
Configure the data limit to 2 GB:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ssh rekey data-limit 2
The following table defines parameters for the ssh rekey data-limit command.
| Variable | Value |
| <1–6> | Specifies the SSH rekey data limit in GB. The default is 1 GB. |
